Creo 2.0 UDF placement without dialog?
lococnc
In the old Pro/E when placing a UDF you would simply be prompted to pick
references in the order programmed when creating the UDF. Now you get a
dialog that you must pick stuff. While this is nice for complex UDF's it is
slower than the old way. Any option to use the old fashion?
0 REPLIES 0
