Hey all. I recently switched jobs and I have gone from using Inventor & AutoCAD to Creo Elements/Pro. The last time I used Pro/E was years ago and it was release 2001i...been a while I know.
Anyways, I still have my personal version of Pro/E 2001i that I used while I was doing private contract work and have gotten set in my ways of how I like the program setup. Creo Elements/Pro is very similar except that I don't see where I can turn Intent Manager off. Personally (at least at this point in time) I still prefer the older menu style of sketching. I know my way around it.
Is there any way to turn off Intent Manager in Creo Elements/Pro 5.0?
Any help would be much appreciated.
Hi John,
Not the answer you want to hear but I suggest you "grasp the nettle" and immerse yourself in the sketcher using the Intent manager. I can't even remember just when I started to use it but it must have been around R 2000i or perhaps R 2001. Once I was used to it I would never go back. I consider it a powerful productivity in my work.
WF5 (Creo/Elements Pro) has several enhancements to the sketcher that are a decent improvement too so you amy want to check up on these. If you are interested I can send you the "What's new in WF5 from Wf4" that I made for our company though this has much more than just Sketcher (i.e. the changes that were of most relevance to us).
Back to the Intent Manager in Sketcher i have some things that I look to do:
Good luck in any case
Regards, Brent
A year late...just looking at the latest release )which no one ever sends me a part using).
Intent Manager was the begining of the end for GOOD ProE models.
It makees for lazy designers with poorly constrained features that update in unanticipated ways.
The one upide, it is good way to identify poor designers. If someone uses it, they probably do half ass work.
John,
If you want to switch off the intent manager permanently you have to switch off esch constraints in options and save that config files and use it. Below are the few constraint options,
sketcher_midpoint_constr
sketcher_parallel_constr
you can get these options for all the constraints.
in other hand, if you want to switch off temperorily, just right click afer sketching entities so that you can lock the constraints applied by Intent Manager. Check this video in youtube for more clarity.
http://www.youtube.com/watch?v=xmOvAnMQekI
