Edit text OS info
unknown1
Edit text OS info
I amn trying to force the command "edit text OS" to fire up notepad rather
than VI, as an editor. No luck so far, any help?
Rick
I know there is a way to redirect it to use the 'textedit' editor in unix
but I don't think notepad can interoperate with CADDS. If that's useful to
you I can try to figure out how we did it. I haven't seen it used here for
a few years but the know-how probably still exists.
S
I am trying to force the command "edit text OS" to fire up notepad rather
Rick
I got my answer, thanks Joe H. It works fine now.
I misspoke, using the term "notepad" rather than "dtpad"
OK, back to work now. I am bouncing between PRO and CV these days, the
best of both worlds.
Rick Henry
fuerst
(To:unknown1)
Was this a .caddrc mod?
1st
Sorry for not posting the answer to my problem.... here it is:
I assume you are using a UNIX variety. If you type "env|grep EDITOR" the
results will probably show "EDITOR=vi". If you are in a C shell, enter
the
command "setenv EDITOR dtpad" and then enter "cadds5" in the same window.
To make the change permanent, add the setenv statement to your .cshrc
file. There are other EDITOR possibilities depending on your flavor of
unix. "notepad" is a Windows editor.
