Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Hello all, I get the following error while trying to run an analysis in the FEM mode using the msc/nastran solver: Error in access solver file(s). Solving failed. Can someone please tell me how to correct this error. Regards
