Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Would anyone have a model or models of floating nut plates that I could download? Or can you point me to a location where I can download some?
I have checked with Pro/E Stuff and Pro/E central. I also have check, but not yet contacted the manufacturer for requested nutplates. I will post the results of my search.
