Can anyone help me in creating parting line for the attached component.
I could not able to do so.
Thanks in Advance
Amit
It seems like the worst spots are the transition from the end diameters to the main body. You can try to tweak those a bit.
Well it aint flat if that's what you want. I rotated the part so the center section is vertical and you can put the P/L where ever you want in that area. The rest really aint bad, do the silhouette curve and then the areas where it dont match 100% just do a projection in that area to smooth it out. Then copy each side as 1 curve and away ya go with a split.
Have fun.
Hi Gary,
I tried hard to create a silhouette curve but withouot success. Is there any way to easily create silhouette curve.
Which way are you trying to orientate it? And which part are you having trouble with?
