Help
AndréLuizM.Guim
Help
Conflict.
Hello, I would like to know how to disable the screen that appears in Creo 1.0, which was not created mass "conflicts" (mass properties are not calculated) next image in question has a solution or not.grateful. ........
André,
open that part and compute its mass properties (Analysis > Mass Properties).
Martin Hanak
Martin Hanák
You can do what Martin said or change option in config.pro
Cheers
thanks, helped a lot ........
