When I open *.x_t file in the Creo 2 I received solid model.
When I open the same *.x_t file in the Creo 3 I received faced model.
How need change setting in Creo 3 to receive solid model after opening *.x_t file?
Viktor,
usually an aswer is related to *.x_t file. If you can upload it.
I guess that PTC modified Creo 3.0 code and therefore the result is different in Creo 3.0.
Martin Hanak
