I have a lot of weak dimensions I need to change. Can I change them all al once?
Yes, change the filter to "dimensions", window select them all, then press CTRL + T
Christian,
Does the information from Tom solve your issue?
CTRL+T didn't seem to work for me. Right click and strong and / or lock did though after windowing them all.
Which version/datecode of application are you using?
