How do I round all external convex and concave edges, but not the internal ones?
brianlynn
ones?
Anyone have a guess, as to a way that is easier than just selecting all of
the edges?
Brian S. Lynn
Technical Coordinator, Product Engineering
7 REPLIES 7
Yeah, sorry about that I am on WF3 still.
Brian S. Lynn
Brian,
If it is a surface, you can use the Vertex Round (see below). Otherwise, for
rounds/fillets on solids, I think that feature is available starting with WF
4.0.
To Trim a Quilt Using Vertex Round
Use Vertex Round to create fillets on outer quilt edges.
Click Insert > Advanced > Vertex Round. The SURFACE TRIM: Vertex Round
dialog box opens.
Select vertices at the corners of the quilt to be rounded and click OK. All
selected vertices must belong to the same quilt.
Enter the fillet radius. This radius will be applied to all selected
vertices.
Click OK in the dialog box.
See Also
About Trimming Quilts
Here are a couple of responses I received.
Brian S. Lynn
Hey there Brian,
For the record, there is a hidden config option that allows you to enable the "round all" feature in WF3. Regrettably, you are limited to all the convex and/or concave geometry without exception. I.E. There is no ability to exclude a single edge or a chain.
allow_round_all yes
(Note the round all options in the feature dashboard once the config has been enabled.)
If the round all were an imperative step (for whatever reason), consider these possibilities:
Build the outside geometry including the round all before building the internal geometry. (Typical model tree manipulation.)
A second option would be to enable the hidden "Remove" feature with the config below. Depending on your geometry, it may be possible to use it to exclude the internal rounds of your part. (Don't forget to include the transitions...)
all_tmp_rmv_srf_feat yes
(Find the feature in Edit --> Remove.)
As with all hidden configs, use at your own risk.
Best wishes,
Jered
Ps. I believe there are youtube videos for these config options.
I stand corrected. (Thank you Terry)
In the Round All feature, the selection methods are as follows:
Shift+click = Deselect items
Ctrl+click = Select items
According to Olaf's config option lists [1], allow_round_all was first a hidden option in 2000i2.
[1] -
www.design-central.com
LinkedIn
The problem, since I am still on WF 3, is that you cannot remove any
convex or concave edges when you use the check boxes for All Convex or All
Concave. If you attempt too, on my system at least, you are immediately
exited from Pro/E.
The option that many of you have mentioned we turned on back in 2000i2, so
I do know the checkboxes exist, but the fact is it is either an all or
nothing situation, you cannot edit the list and you cannot limit it to
just the outside convex/concave edges. I was hoping someone might
understand the find tool well enough to teach me how to select just the
external convex/concave edges without selecting the internal one, so I can
assign a different radius to the external edges vs. the internal ones. I
do not know the find tool may not allow the sifting of information so fine
without knowing more information than it would make sense just to make the
individual selections.
Thank you to everyone who has attempted to help on this,
Brian S. Lynn
