How do i write relation
  • November 12, 2010
  • 2983 views
Hi all,
i am trying to figure out (without success) how to write a relation. I want to control a diameter when another diameter is a given value. For example, if diameter A = 100 then diameter B = 120. I thought the following would work, but it does not, i get error in relations.
IF A=100
THEN B =120
ENDIF
Regards
John
    Hi John,
    try this one:
    if (A==100)
    B=120
    else
    B=100
    endif
    Regards
    Oli
    Hi Oliver,
    thank you for the reply, that worked, sort of. I actually want to add more than one relation, so when A=100, B=120, but i also want when A=110, B=120 & A=120, B=130.
    These are not the actual values i require, i have used them for simplicity, the actual figures do increase by 10 each time, they are more random.
    Regards
    John
    Ok, i figured it out. I dropped the last 2 lines, ELSE & B=100. Now things are working in exactly the way i wanted. Thank you for pointing me in the right direction Oliver.
    Kind Regards
    John
