Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Hi, When I go to create a new model or go into editing an existing model and I hit the sketch button or any other buttons nothing happens. In the text box on the bottom of the screen it says that it is in pause mode. How do I get out of this mess? It seems like all my models are infected.
Select a reference, such as surface, plane or edge to define view orientation. Current tool is paused. Select objects, or Resume to exit Pause mode. Select a plane or surface to define sketch plane. Current tool is paused. Select objects, or Resume to exit Pause mode. Select a plane or surface to define sketch plane.
