How to Sketch?
aminhas
How to Sketch?
Hello All,
any buddy guide me how create this type of Sketch?
top down curve sketch
Side view sketch
Intersect 2 sketches
Sweep
13 REPLIES 13
dgschaefer
(To:aminhas)
It's a bit hard to tell, but I'd say it looks like two simple sketches projected together. Perhaps a circle on top and a shallow arc on the side.
LinkedIn
aminhas
(To:dgschaefer)
can you make a tutorial?
dgschaefer
(To:aminhas)
Swamped right now, but it's fairly simple. Sketch 3/4 of a circle on the top plane, sketch a shallow arc on the right plane (same length front to back) and then use the intersect tool to intersect the two.
LinkedIn
aminhas
(To:dgschaefer)
shallow arc?
dgschaefer
(To:aminhas)
Large radius, fairly flat.
LinkedIn
Side view sketch
Sweep
aminhas
(To:TomD.inPDX)
Sir,
very nice can I get the video?
Please try this with the information posted. Maybe you can post the video once you understand how this works?
dgschaefer
(To:aminhas)
Funny, I came in this morning with this on my mind and decided to make a quick model. Then I find that you've already got your solution.
Oh well, I made the model so I decided to post it anyway. It's in WF4 so pretty much anyone can open it.
LinkedIn
The challenge has changed slightly as the 2 free ends are now straight.
This time I used a wrap feature to better preserve the radius.
Creo 2.0 model attached.
aminhas
(To:TomD.inPDX)
very nice work is that possible make video?
kind regards,
The wrap feature is discussed in this video:
Closed and Ground Spring - Alternative to Helical Sweep
You have to be careful about running the ends beyond the surface. If you check both options in the wrap feature, it may ignore it. However, I have also had it fail. I measured the length of the surface to use in the "U" shaped sketch in the included example.
Patriot_1776
(To:aminhas)
One thing, depending on the desired result, you either want a wrapped curve, or a projected curve. Wrap does exactly that, preserving the overall length of the curve. Project does what Antonius did first with the intersection of two curves, which will stretch/distort the overall length.
