How to create a MCAD board file
ptc-5364582
How to create a MCAD board file i have created the mechanical base board and i have given the co-ordinate systems,orgin but i need to know through which option we should go for route keep-out,place keep-out and height keep-out.
Beside model tree you can see a scroll down in that you can see Tree columns and in that you can select the required options
IF required we can screen sharing session and i can help you.
Contact no:8790532620
Mail ID:-
