On my system is a customized command "OberflaeSymbole" its not a bad one. But unfortunately there is a small error in it and for me that means I have to change the symbol height to change every time from 2.5 to 3.5.
I'd like to fix that but I don't know how to find the file in which the command is located.
Help will be appreciated.
Hi Thomas -
It's hard to give you a quick answer because we don't yet know how the OberflaeSymbole utility was implemented. It would help if you could give us the following information:
I can offer you a suggestion to get started:
I'll leave it to those member using a German-language Creo installation to translate the underlined text above.
If you find nothing in Step 2, then the tool might be implemented some other way, such as a mapkey.
Good luck with this -
|+| M a r k |+|
Hi Mark
Thanks for your response! But it's not about Creo Parametric. It's about "PTC Creo Elements/Direct Modeling". (I hope I'm also right here...?)
"Oberflae" was just abreviated from "Oberflaeche" respectively "Oberfläche" and the Symbol is therefore to describe the surface finishing.
I found the command after I "recorded" my steps in Creo.
