Is it possible to copy a subassembly from one folder to another so as the parts, which it consist of, don't get suffix "_" at the end of their names?
Vladimir_G
Hello, everybody!
When I do it now I usually get these:
Nut_M8
Nut_M8_
Screw_M6
Screw_M6_
Washer_12
Washer_12_
and so on.
Thank you in advance.
Best regards, Vladimir.
s.iyer
(To:Vladimir_G)
Use "Back up" instead of Save As.
KrisR
(To:Vladimir_G)
When doing Save as Copy, you have three options:
  1. Template
  2. Prefix
  3. Suffix
You have to choose one of these options. I tried playing around with the template option to see if you could use asterisk space asterisk, but it did not work.
I do not see a way to do it without using one of the three options.
s.iyer
(To:Vladimir_G)
Vladimir_G
(To:s.iyer)
Good morning,
thank you very much for your answer!
I didn't pay attention to this option but now I realize that's a great one.
