Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
M18x1.5 thread does not appear in Pro/E ISO hole tables
Hi to all,
I just tried to make a hole (Fine Metric) M18x1.5, which does not exist in the default ISO hole-table. Pro/E provides data for M18x1, M18x2, and M18x2.5 but NOT for M18x1.5. I googled a bit, and find out that the fine metric pitch for the M18 hole is 1.5 (in some cases I've found M18x2 as FINE) Does anybody of you ever used a M18x1.5 hole so she/he would like to share with me this data, in order to update the ISO hole-table?
