Mannage text styles
visu
7-Bedrock
Mannage text styles
Dear Folks
I have opened empty format
On the annotate tab, Mannage text styles
Created some new styles of text
And i restarted the pro_e
May i know why the created text styles not available? in mannage styles(Default,2D_hyperlink,3D_hyperlink,none) only available?
May i know how to save new text styles? and in which location all the text will save?
Thanks in advance
Regards
Viswanathan.K
Andrew_410
(To:visu)
I too would be interested in learning how to do this. I have just sarted hunting around for a solution today but have yet to discover the correct way.
A quick look says that you can manage text styles in you current drawing or format and they will stay with that drawing or format. However, I do not see a way to save them for use in other parts. Therefore, they are best managed in your template files by creating the alternates.
Welcome to the forum, Andrew.
