Mil Spec Hardware
wfalco
Mil Spec Hardware
All,
Does anyone know a cool website that I can cross reference Mil Spec numbers with description?
For example: If I have a 10-24 screw, I'd like to see a listing of ms numbers.
WayneF
Has anyone seen this... When I save a PDF output (WF3), I get the
hidden lines overriding the solid lines in the drawing as seen below.
Is there a fix for this?
Hi all,
If I have a 10 decimal point number, for instance 1.0000000001 in
sketcher, that wants to keep it's 10 places, is it the relative part
accuracy I need to change? And if so, what would you change it to?
Stefan
