Multiple Lines of Text in a single Sketch?
mrproe
Is there a way to have Multiple Lines of Text in a single Sketch?
Example:
* Improper use may cause
a hazardous condition, etc.
DKL
mrproe
(To:mrproe)
Sorry what I want is to have Multiple Lines of Text in the same text entry in a single Sketch?
Example:
mrproe
(To:mrproe)
This is not possible.
A work around is to create a symbol of the text then place it using the annotation feature.
But this will only work on a flat Datum Plane.
DKL
From
Technical Support Engineer
Technical Support
PTC
Contact Technical Support
