Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
You should post this on the network board. I think you'll get some responses there. Also, let me know what part of the country you are in and I'll tell you if I've heard of any openings in your area.
We are currently looking for a couple detailers. We also just lost an engineer but I think they are looking more to replace him with detailers that we haven't been able to find. Our plant is in rural south central Nebraska. Reinke manufactures center pivot irrigation systems and semi-trailers. We are using 2001 with the move to WF2 pending new machines.
Jim Steinmeyer Design Engineer Reinke Mfg. Co. Inc. Deshler, NE 68340 402-365-7251 Fax 402-365-4370 jimsteinmeyer@reinke.com
www.Reinke.com <http: www.reinke.com=">
