Nested mapkeys
MichaelBerinde
Nested mapkeys
I'm trying to use a nested mapkey for a new mapkey. Each one works separately, but for some reason on the new mapkey the nested one doesn't run. Any ideea? Thank you, M
This involves 2 steps. Step 1. Define the individual mapkeys (say first mapkey for rounding edges and second mapkey for chamfer) Step 2. Define the third mapkey ( this will perform both fillets and chamfer).You need to use first mapkey and also second mapkey while define the third mapkey. I have used this method, it works. -Chander [/b]
