Pro/Animation rotation question
brianlynn
I want to rotate several elements around a hinge point, but I cannot
figure out how to specify the hinge point.
What am I overlooking?
Thank you,
Brian S. Lynn
Technical Coordinator, Product Engineering
No mechanism application available.
Brian S. Lynn
Alright, you can all laugh and point, because I was being an idiot. We do have mechanism, I just never had a reason to use it, nor has anyone else here and since PTC usually charges for extra functionality, I didn't even bother to look when Krystal mentioned it.
Krystal, I am sorry for discounting your educated experience out of hand.
Now I have to learn another application to figure out how to rotate this control panel out of the way.
Thanks for all the input,
Brian S. Lynn
MGortner
(To:brianlynn)
You don't necessarily need Pro-Mechanism. We do not have it but I can still assemble components using pin connections (utilizing an axis in each part) and rotate parts using snapshots for animations. Another module may allow it.
-Matt G.
MGortner
(To:brianlynn)
I've looked through the options on the forum but I can't find what I'm
looking for - something that will keep me logged into the forum for more
than 20 minutes! I use "proe" as a keyword in Firefox to open the forum
and I have to log in every single time. If I search the forum and leave
my computer for a little while, when I return, I have to log in again!
I'd prefer an option to stay logged in permanently.
-Matt G.
