Problem with dxf imported
Hello ,
I'm a new ptc Créo user. I want to import a dxf file and work on as a sketch. When I import my dxf file , ptc créo tell me this : " You tested too many entities in the draft. When the manager of intentions is active, the treatmentof so much of entities is likely to take much time.You can click on selecting to open under windowand to select the entities to be imported"
but I need everything in my dxf. Do you know a method to avoid this problem? ( I already change my DXF into DWG just for see and same problem !)
ps : sorry , my bad english
