Questions regarding Pro table (global text justification, add / remove entire column & row).
jgfrankusa
Pro Gurus:
- I have to create many non-parametric tables of different size
through out the day. It's a real pain and time consuming to click
each individual cell and set the justification text to Center and
Middle. Is it possible to set up all the cell justification to Center
and Middle globally?
- A 10x25 table is already created. I would like to remove an entire
column and row to make it 9x24 or add one more column & row to make it
11x26. Is this doable in Pro Table without starting from scratch?
Thank you for your time and help.
Frank
0 REPLIES 0
