Set display style to shading
LarsZiegler
8-Gravel
Hello!
There is a possibility to set the display style of the model to shading?
Thanks, Lars
Hi Lars,
You could set the config option "display" to "shade".
In TOOLKIT this can be done with ProConfigoptSet.
You will probably need to call ProWindowRepaint to
update the display.
Have never used this myself, but it should work.
Frank
Am 10.12.2013 09:39, schrieb Lars Ziegler:
> Hello!
> Thanks, Lars
Hello Frank!
Thank you!
That works perfectly!
Greetings Lars
