Skeleton Model Color
dgschaefer
Creo2 M080
I'd like to change the default skeleton model color, or more accurately, the transparency. The default blue is OK, but making it 75% transparent seems to help in working with it.
I've found the option "skeleton_model_default_color" but as documented it only seems to be able to change the color, not the transparency.
Any way to change the skeleton model's transparency?
LinkedIn
I don't think there is a config for it.
You might try making a skeleton model start part and set the color/transparency in that. Then, when you create a new skeleton model pick that as the template. I know it's not much of a savings in doing this over just having a transparent color in the color map.
