Summary: Where to find Pro-E models of kitchen cabinets,and furniture?
ptc-726111
No luck in finding any Pro-E models of kitchen cabinets. However, one user already had a similar idea, and sent a JPEG image as proof. I do not have these files myself.
I see this person holds tight tolerances on his/her cabinets.
.XXX = +/-.005
and angles are at ½ degree
Pro/E is not used for Architectural Design unless it is used for Architectural Design. Our company has been using Pro/E for Architectural Casework and Millwork for 4 years now very successfully. Unfortunately, we can not give out our models...I just wanted to add my 2 cents. PS: It is also used in the jewelry industry as well which is not a mechanical application.
Pro/E can be used for whatever you want - it doesn't know the
difference. It just depends on what level of functionality you need out
of it. As a Mechanical Engineer, it's perfect for designing medical
implants. As a homeowner, it's sufficient for designing garages,
closets, decks, etc. I probably wouldn't use it if I were an Architect
doing building design everyday.
Just my .02!
