Summary "Is it possible to change the Hatch spacing globally in detailing?"
jgfrankusa
Pro Gurus:
I hope that all of you have enjoyed your week-end.
Here are the answer that I receive:
Apparently there is a controversal of opinion. Two users say that it
is possible other no. I would like to try suggestion #1; however, the
"copy" option is grayed out. Am I missing something?
The 'Copy' option is not available when the highlighted part is not
sectioned in both/all views.  Click on next or previous until there is a
part highlighted in both/all views and then the copy option should be
available.  In fact, you cannot change the hatching until you select
'copy'.
Doug Schaefer
LinkedIn
