MENU
Start a topic
Search
LogIn
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
All community
This category
This board
Knowledge
Users
Turn on suggestions
Close X
Community Tip
- Need help navigating or using the PTC Community?
Contact the community team.
X
Community
Creo (Previous to May 2018)
Creo Modeling Questions
Suppress import geometry check errors?
Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
MGortner
10:16 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Notify Moderator
Sep 08, 2009
10:16 AM
Good morning all,
Is there a way to suppress geometry check errors you get when
opening/importing a neutral (stp, iges) file?
Matt
Matt Gortner | Mechanical Engineer
CHASEDESIGN, LLC
1400 East Genesee Street | Skaneateles N.Y. 13152
315.685.1000 (p) | 315.685.5021 (f) | www.chasedesign.net
Tags:
creo_parametric_proengineer_cad
ptcuser_portal
Preview file
10 KB
All forum topics
Previous Topic
Next Topic
2
bfrandsen
(To:MGortner)
Sep 08, 2009
10:27 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Notify Moderator
Sep 08, 2009
10:27 AM
Hi Matt
Set config.pro option: show_geom_checks_on_creation no
It will import without stopping at every error.
Bjarne
"Matt R. Gortner" <->
08-09-2009 16:19
Please respond to
To
cc
Subject
[proecad] - Suppress import geometry check errors?
Good morning all,
Matt
CHASEDESIGN, LLC
www.chasedesign.net
-----End Original Message-----
Preview file
10 KB
MGortner
(To:MGortner)
Sep 08, 2009
10:37 AM
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Notify Moderator
Sep 08, 2009
10:37 AM
Thanks. That does the trick. Previously, I saw that config option but
mistakenly thought I already had it set to no.
-Matt
Preview file
10 KB
Post Reply
Business Continuity with Creo: Learn more about it
here
