Suppress import geometry check errors?
MGortner
Good morning all,
Is there a way to suppress geometry check errors you get when
opening/importing a neutral (stp, iges) file?
Matt
Matt Gortner | Mechanical Engineer
CHASEDESIGN, LLC
1400 East Genesee Street | Skaneateles N.Y. 13152
315.685.1000 (p) | 315.685.5021 (f) | www.chasedesign.net
Hi Matt
Set config.pro option: show_geom_checks_on_creation no
It will import without stopping at every error.
Bjarne
"Matt R. Gortner" <->
08-09-2009 16:19
Please respond to
To
cc
Subject
[proecad] - Suppress import geometry check errors?
Good morning all,
Matt
CHASEDESIGN, LLC
-----End Original Message-----
MGortner
(To:MGortner)
Thanks. That does the trick. Previously, I saw that config option but
mistakenly thought I already had it set to no.
-Matt
