Before the symmetry constraint button one would have to use a displacement constraint and select the corret dof's.
Using the 'old fashoined' method it is possible to create constraint reation measures.
In Creo2.0 M060, it is not possible to get reaction forces for a symmetry constraint using the symmetry constraint 'button'
I have not tested in earlier versions of the s/w.
Is there a reason for this?
