Template Directory default in Configuration Editor
I can assign a default template with template_drawing and I can assign a default open location with File_open_default_folder but it has limited options that do not inlcude Windchill. Seems like there should be an option for this same as formats (pro_formats_dir). I want to avoid our users having to browse to a location every time they need to use a different template than the default. How do I assign a default Directory for template locations in Configuation Editor?
