Text orientation verticaly
opavot
2-Explorer
Hi all I have a basic problem , I want to creat a text with vertical orientation , If you have the solution , can you teatch me Many tahnks for your help Olivier
Olivier The easiest way to do this to create a note and type in one character then use the return key on the keyboard, type in another character, then return and etc. Pro-E will finish the note once you have given it two returns in a row or select the green check mark in the right-hand corner. Eric
opavot
2-Explorer
(To:eric.mills)
Eric Many thank for your help , but I made a mistake when I asked my question , in fact I want to creat an engraving on my part and with note it don't work . I found a solution to do what I want but I have to creat the letters one by one , If someone have the experience to create all the letters in the same time it will be great Olovier
