Tweak Replace?
davehaigh
Tweak Replace?
Way back before the Wildfire interface there was a command called tweak replace.
Anyone know what that called now and how to do it?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
4 REPLIES 4
David,
Its under Edit, Offset. Pick your surface, Edit, Offset. In the dashboard change the icon to the one that says Replace if my memory serves me correctly.
Mike
It's a subset of the offset tool.  Grab the surface you want to replace
and select edit -> offset.  Then, on the offset dashboard, click on the
icon at the far left.  A dropdown menu will appear and replace is the
bottom pick, I believe.
Doug Schaefer
LinkedIn
Replace is also in the right-click menu when you’re in the Edit -> Offset command. Faster for me than figuring out which icon is Replace in the dashboard (but Doug’s right, it is the bottom one).
Nate Venskytis
Product Development
Schick/Wilkinson Sword
An Energizer Company
10 Leighton Road Milford, CT 06460
Tel 203 882 2154 • Fax 203 882 2548
hippe
(To:davehaigh)
Don't forget about the menu mapper on ptc.com to determine unfamiliar menu picks: http://www.ptc.com/community/proewf2/menu_mapper/en/index.htm
Although Creo Elements/Pro 5.0 is not fully mapped yet, if you map from previous versions to WIldfire 4.0 with the exception for detailing, you should see the correct picks for CE/Pro 5.0.
