Unlink-ed sketch
ptc-592974
Unlink-ed sketch
Wildfire 2.0 - M050
I created an independent sketch. Then I created a protrusion using that
sketch.
During an edit, I clicked the unlink button.
How do I "re-link" the protrusion back to the sketch without deleting the
protrusion and starting over?
You should be able to just re-select the original.
Un-linking I think basically creates an independent copy in the feature.
Thank You,
Vaughn McDaniel III
Mechanical Engineer
JR Automation
13365 Tyler
Holland, MI 49424
Ph 616.820.3330
Fx 616.399.4443
_____
