Upgrading to WF4?
A.DelNegro
7-Bedrock
Upgrading to WF4?
I'm contemplating moving from WF3 to WF4. I'm wondering if there is a
preferred stable build.
I don't have any outside constraints like PDM systems and such, just my
reluctance to move to a less stable product. When I went from 2001 to
WF2, it wasn't that stable. We quickly moved to WF3, which was better.
At the moment, I only have build M060 available since we are off
maintenance. Does anyone have any issues with this build?
Thanx
Tony
Correction, I do have a copy of M070.
Tony,
I am having good experience with Wildfire 4.0. M070 is quite a older date code release. We keep upgrading to latest datecode releases as soon as newer datecode release is available.
I have worked with M070 without any problems. However I would recommend you to get the latest datecode release of WF 4.0 which is M130 because the later the datecode, the more stable the product is.
~Ash..
