Variable patterning in Wildfire
unknown1
On the dashboard, left most window, change from Dimension to Table and you
will be able to pick all the dimensions you would like to alter.
Bill Kunz
MCAD Specialist
Alcon Laboratories, Inc.
(949) 753-6709
william.kunz@alconlabs.com
Use the Ctrl key to select multiple dimensions in a single direction.
Just like any other feature in Wildfire
Thank You,
Vaughn McDaniel III
Mechanical Engineer
JR Automation
13365 Tyler
Holland, MI 49424
Ph 616.820.3330
Fx 616.399.4443
