WF 2.0: what is a "common name"?
lbeidler1
This field is directly mapped to a new string parameter called PTC_COMMON_NAME. This parameter is used by PDMLink to display the "Common name" of a part (ie. Bolt, Screw, etc)
-Darin
http://www.ptc.com/cs/tpi/124152.htm <http: www.ptc.com=" cs=" tpi=" 124152.htm=">
