WF2.0 Symbols, offset placement usage
  • February 17, 2006
  • 0 replies
  • 320 views
To place a symbol with 2001, it was placed using offset, & then
selecting the object you wanted the symbol attached to.
In WF2.0 M170 it does not seem to let me select offset, I have to 1st
place the symbol then reselect the symbol & select properties, then I
can choose offset & select the object to attach the symbol to.
In 2001 for rev balloons, gages, KPCs, rev blocks, & many other things
it was quite easy to just select a existing symbol (like a rev block),
map key up the properties, then modify a few of the fields, & place it
again (offset or not). Less mouse clicks & time.
In WF2.0, I now have to bring the symbol in, populate ALL of the
fields, then place.
Maybe I am missing something here, but symbol usage appears to be more
clicks/time & trouble than before. Anyone have a solution?
So far, that is my only real complaint about WF2.0. Other than that,
WF2.0 is a major upgrade & I am loving it.
