Wildfire 5.0 Curve Projection Technique
ira.winston
Pro/Users (or should I say planetPTC'ers?), Back at it again with another link to a short video tip from acontributor (AB) at Pro|HOMEPAGE. This isa new Wildfire 5.0 technique that slipped through the cracks until recently discovered. If you Project curves, you will like this one. Yes, it is a very specific case, but we have already found several scenarios where this is a big time saver.
0 REPLIES 0
