aligned dims not staying that way
davehaigh
I selected two dims and made them aligned.
[cid:image001.png@01CE8DFF.CC900310]
I then drag selected both, and selected between the arrows on the right dim and dragged them up and down.
[cid:image002.png@01CE8DFF.CC900310]
As you can see, they are no longer aligned.
Creo 2.0-m060. This didn't happen in WF4, they would stay aligned when you moved them.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
Hi David,
I just confirmed the same behavior exists in Creo 2.0 M050. It appears, at
least in my case, that the two do not become misaligned if I move the
dimensions by selecting on the dimension value itself. They only become
misaligned when I select the line of the dimension arrow. Good catch...I
hadn't noticed this until now.
Mike Phillips
Raytheon Company
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
