closing pro_comm_msg.exe
vemanamar
Hi all,
I have been working on J/Link. I am facing with a typical problem while
closing PRO/E.
When I open Pro/E through J/link with having graphics mode, then exiting
the PRO/E application through J/Link also ends pro_comm_msg.exe process.
But, if I do the same with out having graphics mode, pro_comm_msg.exe
process is not being closed.
Can anyone help me out in this regard?
With regards,
V.Amar
pwilliams-3
(To:vemanamar)
V.Amar,
I am pretty sure that this is normal behavior and pro_comm_msg.exe will
stop eventually. I wouldn't worry about it too much. Is it causing
problems?
Patrick Williams
Sr. Application Engineer
Steelcase Inc.
pro_comm_msg has a default timeout which I believe to be 300 seconds.
When you start it, you can specify another timeout. I don't remember the
syntax to specify the timeout. I believe you can do it on the command
line or with an environment variable.
Bob Monat
Robert A. Monat
Jerand Technical Services, Inc.
http://www.jerand.com
Phone: 317-875-6087 FAX: 317-875-6612 Tollfree(US)888-4JERAND
Amar Vemanaboyina wrote:
> Hello Patrick,
> Thanks for your response.
> If I run a j/link application with out graphic mode for many a time,
> some times I am getting connection start error, like XToolKitBusy. To
> get rid of this, either I will log off my system or restart my pc.
> Other way around I do is, in TaskManager (of WIDOWS_XP OS), I will end
> the pro_comm_msg.exe process.
> Regards,
> V.Amar
Hello Patrick,
get rid of this, either I will log off my system or restart my pc. Other
way around I do is, in TaskManager (of WIDOWS_XP OS), I will end the
V.Amar
