hy
creo have a ruls and logical for constraint in ansembly
i work for 'a project" named "minimize the mouse click"
the general constraint i use is coincident and distance but freqvently coincidence
how make this default
any solution and idea is welcome
tks people
A quick look in my config.pro file shows a parameter called
auto_constr_always_use_offset
Here's a thread that concerned what you are looking for. It's often faster and more of a happy time to search first for what you're asking, so you can get all this past knowledge.
automatic constraints settings?
Also, note in the "MORE LIKE THIS" bar at the right side of the window, you'll see more suggested discussions to look at.
