color for new plane creted by me
hello people
i have a wish when i create my plane different for front top or lesft i want to have a different color for example black
how i do this ?
what parameter control color of planes?
    Redro,
    I'm not sure if you can do that, however you can change the color of the datum planes doing this. Also remember that you can select the default datum planes directly from the model tree, so you are able to identify them easily.
    all datum planes share same positive/negative side color. This color can be changed using a procedure reported by Ruben Alejandro Villarreal Barrios.
    MH
