company formats in WF#
tj
Hi all, We have a company wide format which includes tables (e.g. p/n, revision, distribution, ecr info, etc._ In Pro/E 2001 it is brought in by: sheets format add/replace where the HECK is this in WF3?? 😕 thanks!
tj
(To:tj)
when bringing in the format the user is prompted to fill in each field in each table within format layout
iturner
3-Newcomer
(To:tj)
Try file, page setup
Hi, Open a dwg file, right click on an empty area & select page setup under format drop down u can select the required format ex d.frm,e.frm etc. you can also browse and specify the location of ur own format file.
