Please share if any one knows
Select both surfaces holding control, then select intersect in the editing group of the model tab. That will create a curve at the intersection of the two surfaces.
Thanks Tyler, that's what I'm trying to do but the intersect command is greyed out
Once you have a surface selected the intersect command should not be greyed out.
Thanks for your help, user interface has changed so much since last used creo..I should say proengineer ![]()
