dialog box window not big enough
columicious
Who is the genius programmer that made the limit boxes so small I can
only see two whole numbers on my angle?
(The value entered below is really 240 degrees)
Same guy who sized the reference boxes at the left (under 'Rotation
Axis') that are also far too small for the data they contain.
Doug Schaefer
LinkedIn
