Can help me someone?How can I set arrows style on default when I open a new draw in the creo 2.0
Because I don't want filled arrows.I remember draw_arrow_style in the Wildfire 2.0,but I don't find it in the Creo 2.0
Is it replaced? Thank you for you helping
HI,
in the drawing window..go to File>Prepare>Drawing Properties.... you find detail options there..there you will find ARROW_STYLE option
text size can be adjusted at the same location as above:- option name "TEXT_HEIGHT"
HI,
it is only known as ARROW_STYLE in Creo2.0..the"DRAW" word has been removed.
Thank you for your answer.
However I have no idea to find where the ARROW_STYLE is?
By the way, could you please help me to set up text size of the dimension ?
HI,
Thank you very much
