history tree
al204
history tree
is it possible to save the configuration of the history tree and use the same configuration over and over?
thanks
al
using wf 3.0
davehaigh
(To:al204)
Yes, it's call a tree config file. You can name them what you want, and create mapkeys to load them. An example is attached. The save and load menus are where you define the columns you want to see.
David Haigh
